dana 60 ?
mufflerman
RE: New To The Jeep Thing
im looking for a dana 60 0r any 3/4 or 1 ton axle with pass side diff ? what year ? what make any body?
chevy or gm, almost all years. late 70's seems to be the most popular but theyre almost all the same until they switched to using balljoints instead of kingpins just recently
RE: More Offroading Pics - From Sept
Don't forget the Dodge front 60. They are similar to the Chevy except they have a different external hub and are a few inches narrower. You could probably score a front and rear together for less than a Chevy front alone.
RE: installing engine-any good manuals?
Chevy front D60s are up to $2000 a piece around here if they know what they've got. I was quoted $2500 for the last one I managed to find that was for sale. Dodge front D60s can be yours for $500 if you look around.
I can buy an old worn out, but running, 1 ton Chevy worktruck cheaper than I could buy just the axles in a junkyard around here. How freakin stupid is that? :roll:
Re: Thanks for all the responses.
another good option is to look at government auctions and pick up an old truck with d60 front 14 bolt rear. m1308's maybe? im not sure what theyre called but a buddy of mine bougth one for 1200 and got a 60 and 14bff, with 4.56's
Bingo!!!! They are M1038 CUCV's That's what I've got. They are geared 4.56 and the rear has a Detroit installed already.
Chevy 60 fronts around here go for $1200 if they are complete with the brakes. Always make sure you get all the brake components cause they are expensive.
There is nothing wrong with the Dodge stuff, just takes a different style hub. The axles are just as strong.
The trick around here to getting a nie axle set up is to buy a 73-87 chevy 3/4-1ton that is running, but rusted out beyond belief, you can generally get the whole truck for $500-$2000 depending on condition. scores you a 350, matching d60 front, 14 bolt rear, np205 (usually) and SM420/465 if it is a stick.
