1042132
Help me, please! I've got an '89 YJ. It was drinking gas, so I replaced the carb with a 2bbl Carter with NO stepper motor. I had already done the Nutter bypass. Immediately after the carb replacement it would start perfectly when hot or cold, but when it cools down for about 15 minutes, it cranks for a long time before it will start. It always DID start perfectly BEFORE that freakin' Bubba changed the carb. The ONLY thing that changed up to this point was the carb. Since then I've changed the coil, wires, plugs (to a later Ford high-energy), this made it run so much smoother! I also had an intermittent cutting-out problem, so I replaced the distributor and electronic ignition module. It runs extremely smooth and pulls like a train. BUT, after all this, I've still got that hard starting problem when it cools down. I'm at my wit's end. I've thrown away almost every piece of vacuum hose, all I've got left is the one going to the distributor advance (it's connected to the right port according to the paper that came with my carb. The carb was a rebuilt Autoline. Can anybody help me? Please and thank you!
