91-95 FSM help
laneiac
RE: Door Removal
As you may or may not know, my fiances' 93 was broken into and the doper ripped apart the column and such. Well, everything is replaced, but its being driven with out the lock plate, spring and horn because I put something together wrong. Cant get the lockplate to compress the spring far enought without hitting some of the internal column pieces. Anyone have an exploded diagram of the column and turn signal doo hickies? If you could hook me up that would be great... Thanks.... Justin
Sooo... no one has a fsm for a yj that they are willing to help me out with??
RE: death wobble woes...
is it a tilt wheel or non-tilt ? i have the fsm but there 10 pages for each. which one do you need
RE: high beams work, low beams won
Its non tilt. If someone could help out I would be so grateful. We are going to sell it soon and need to get it back to the way it was.
