93, pulling transmission
kaw2000
I have a 93 Grand cherokee 4.0. When dropping the transmission do I have to remove the exhaust. Its tight but it appears that if I can pull the transmission far einough back it will clear. Thanks for any help.
You should be able to remove the transmission assembly without removing the exaust. It will be a tight squeeze..
I was able to do it in my regular Cherokee. It took two jack stands and 2 people. It worked but it definitely is a tight squeeze.
i just pulled my transmission on my 89 xj. i pulled the exhaust made it a little easier. but i have a borla cat 4ward. which makes it really easy to take off the exhaust ( one pipe clamp and its off at the header)
