Yep. If you are looking up parts for a YJ steering column, it is called a GM Saginaw column. Same exact internals as found in the 80-94 GM pickups. As well as some Toyotas. The tilt column that I installed in my 87 was from a 93 C10 2wd pickup. The only thing I had to change was the mounting plate where it bolts to the firewall
