97 ZJ suspension
Appleshack
I have a 97 ZJ Laredo and need a little more room other than the small 2 inch lift blocks I have
I have heard that the front coils can be replaced by the supposedly taller coils on the limited model because of the heavier v8
The existing front coils then replace the back coils, is this true and/or would this work??
Thanks,
Cody
Those will be shorter than the springs you have plus spacers. In my opinion if you are going more than 2" you will need a full short arm kit. The stock control arms will not handle the extra stress from being at a larger angle from the frame.
Thanks!! I'll just stick to my 2" and put the little tires back on :( haha
also i see that you have wheel spacers. whats your opinion on those? any problems?
Spacers are great. They give an aggressive look and help clear the tires. Just use oodels of lock tight.
