xt master
I had a problem last winter that when I went to start the Jeep it was dead.I replaced the battery and still had problems off and on.I replaced the terminal ends on the wire and the problem seem to go away.Now it is cold out again and the problem returned.It was dark out and all I did was grab all the wires near the battery and shake and it started up.What suggestions do you have.It only seems to happen if the temp is below 10 degrees.No problems all summer long.:???:
