kreatos909
hello everyone and thank you in advace. i have a 95 xj 4.0 h.o. i have dual fans running at 30 amps combined. i recently got my ac fixed and its been running around 210 -240. i do have an 18psi rad cap off a 5.2l . is that to high? also i have done the head gasket cause it was blown, and opened up cooling passages on both sides of head. cause right side was blocked. as well as 180 degree thermostat, which jeep runs at 185 usually. also just replaced water pump as well bearing was screaming.
