CJ7 Tarnsfer case crossmember help
William1982CJ7
Hello all !
I have a 82 cj7 with a Dana 300 transfer case and it seems to be missing a mount at the crossmember. It seems to have one mount there but nothing else. I can see where there are bolt holes and such on the other side but nothing is there. There is also some cheesy metal bracket between the case and the crossmember. The problem is I have no idea what it is supposed to look like!! Is there any chance someone can post a diagram or a pic to help me understand ! I appreciate any help you can give !
No pics but i'll try to explain. There should one rectangle shaped mount directly under the transmision with bolts or studs going down threw the skid plate. On one side of the mount, just a few inches away there should be a long bolt with rubber bushings on each end, threw a mount on the side of the transmision and down through the skid plate. It's called a torque bolt. All of the other holes in the skid plate are for other applications and to confuse people.
