73cj5guy27
hi trying to figure out my 73 cj5 304 V8 with 3 speed. the clutch was done wrong cause of the body lift. i took it off and then unadjusted the adjuster from the frame to the trans to were everything is set right and readjusted it and now i have 3 1/2in of play in the pedal and my book says 1in max. well when the clutch is pushed in it stops at 4 1/2in and cant go anymore. the fork on the trans only moves 1in and stops and wont move anymore. is this normal or is something messed up form the guy putting the body lift on it and adjusted the hell out of it, cause i have to start it in gear and as im starting it it starts moving and cant shift into any gear if started in neutral. so could the clutch be bad or something
