Engine rebuild
Brian Z
To make a long story short, I wanna rebuild my 4.0. I have some one willing to do it cheap, ( yes, he's a mechanic ) not in a rush to get it all done, cause I'll be doing the rest off the jeep too. who offers a rebuild kit? I have looked a couple places, but all they show is trans build kits. any ideas? thanks
You would have to source stuff individually. The bearings you have to order at time of rebuild as they use a numbered system so the crank needs to be measured to get the proper bearing for each journal. If your going to bore it then I suggest upgrading to a hyperutectic piston.
Hesco inc sells parts, crate engines and worked engines they build. I don't know if they have a full rebuild kit but it is worth looking into.
