yj windshield washer tubes
daveplot
RE: Spicer U joints
Whenever I try to clean my windshield no fluid comes out of the spray nozzles. The pump pumps fluid out, the fluid isn't making it through the tube. I have my dash off now, and figured I'd try to fix it now.
Does anyone know how to access the tube behind the airboxes?
Can't tell you how to get to the tube, but first make sure the nozzles aren't simply plugged...which is pretty common.
RE: Turn signal fuse replacement
The hose from the resevoir runs into the fire wall inside of the cowl. Remove the nozzles on cowl, check to see if blocked. If you remove the hose becareful not to let fall back into the cowl, they are a pain to get back out. Operate with the nozzle off to see if you are infact getting water/fluid through the hoses. If you are getting fluid the the nozzles are bad and according to the chrysler shop manual they are not repairable, they recommend replacement.
mike
