    Cool Dynatrac Pro Rock 44 Front Axle Assembly!
    Still great deals to be had on the Pro Rock Dana 44 by Dynatrac!
    (normal truck freight in lower 48 states + applicable taxes).
    I am a Dynatrac dealer and are offering the Pro Rock 44 to you either as a direct replacement for your factory D44 or as an upgrade from the D30.
    Pro Rock 44 PDF here!
    Standard specs:
    * Complete custom Pro Rock 44 front axle housing with 12 month limited warranty
    * Custom machined Dynatrac high ground clearance, high pinion (reverse-cut) heavy duty nodular iron housing
    * Axle width 65.5” (stock JK) when outfitted w/stock wheel ends
    * Standard housing geometry, pinion angle, and wheel alignment for customer’s suspension
    * Uses new generation JK ring and pinion
    * Dynatrac Pro Series nodular iron differential cover
    * Dynatrac Jeep coil spring bracket set (Includes heavy duty brackets and installation, trac bar bracket & shock mounts included)
    * Heavy Duty 3.0” X .313”(5/16th”) wall DOM housing tube assemblies
    * Dynatrac Pro Series extra strength end forgings w/ball joints installed
    * Detailed and painted Dynatrac’s signature gloss black
    Optional Installed Add-On Differentials - Complete w/Master Install Kit:
    * Tru Trac heavy duty limited-slip differential w/R&P choice and 1310 yoke
    * Detroit SofLocker differential w/R&P choice and 1310 yoke
    * ARB Air Locker differential w/R&P choice and 1310 yoke
    * Electric selectable locking differential (JK Tru Lok) w/R&P choice and 1310 yoke
    Custom axle shaft mfg choices are numerous. If you want the RCV shafts, I sell those as well but you should run either the Pro Steer upper and factory lower ball joints or both factory joints.
    PM for quote: (include any options wanted, shipping location and whether residence or business).
    Thank you very much! I am grateful for your business.
    Allen
    Allen's Offroad - 530-620-1100
    Email me at: sales@allensoffroad.com
    Be careful what you wish for. It will come true!
    Never miss a good chance to shut up! - Will Rogers
    Re: Dynatrac Pro Rock 44 Front Axle Assembly!
    Looking to upgrade your front axle and don't want to put a bunch of money into a Dana 30? Shoot me PM or post here for a quote to your door on an easy replacement Dana 44 front with a HP and made in the USA.
    Thank you! I am very grateful for your business.
    Allen
    Bump for bonus offers.
    Allen
    BTT for free shipping promo!
    Thank you!
    Allen
    bump for end of year shot at getting a great front end for snow runs or spring wheeling.
  6. Re: Dynatrac Pro Rock 44 Front Axle Assembly!
    Do the Pro Rock 44's come in a smaller width? I'm looking at replacing the HP 30 in my TJ. A 65.5" WMS to WMS axle is too much. Could you let me know what you have for TJ HP 44's? If you have something, shoot me a quote for a HP44 with 4.88's, either open or with an OX, and Inner's (I plan on using the 30 outers/brakes ect.) and shipped to 56021. If you could shoot it to my email that'd be great JPWillyCustoms@gmail.com
    Thanks,
    Paul
    '97 Slinky
    North Shore Wheelers
    www.nsw4x4.com
  7. #7
    Quote Originally Posted by jeeperwilly View Post
    Thanks,
    Paul
    Email sent. Thank you for your business. I am very grateful.
    Allen
  8. Re: Dynatrac Pro Rock 44 Front Axle Assembly!
    Thanks again Allen. Great guy to work with and I'd highly recomend!!!!
    '97 Slinky
    www.nsw4x4.com
  9. Could they be bolt in ready for a YJ with a 4" lift?
  10. #10
    Quote Originally Posted by blacksheep View Post
    I am sorry but they are not currently available for the YJ leaf spring configuration. I can get you a Currie Enterprise unit though. PM me the specs you are looking for and your zip code. I will put something together and get back to you.
    Thank you for the kind words of praise Paul. It was my pleasure sir!
    Namaste,
    Allen
  11. #11
    Great upgrade for your TJ, XJ, or JK D30 guys and gals. PM or post here with questions or to order.
    Thank you very much! I am extremely grateful for your business.
    Namaste,
    Allen
  12. #12
    Hello, could i get a quote for an 06 tj, no innards?
  13. #13
    Quote Originally Posted by JeepNaked View Post
    Cody,
    just the housing, carrier caps, Nodular iron cover for your TJ with factory joints, and brackets installed is $1895.00 plus any applicable taxes and shipping. What is your zip code?
    Also, I must tell you that the PR44 does not use TJ anything inside. You will need custom length inner shafts (or RCV shafts), a JK carrier 3.73< for 4.10 and numerically higher ratios, and they use a thick R&P. The PR44 center section is based off the JK D44 front. So it comes in both factory offset for the JK E-Locker or machined for after market Detroit Soft Locker, TruTrac, or ARB.
    Namaste,
    Allen
  1. Front end assembly
    By Burger in forum Wrangler and CJ
    Last Post: 02-28-2010, 03:49 PM
  2. wanted rear axle assembly?
    By mgmckenna in forum Items for Sale, Trade, or Give Away
    Last Post: 03-15-2009, 07:56 PM
  3. Front axle shafts Which one's Rock ?
    By droopey in forum Wrangler and CJ
    Last Post: 02-12-2007, 11:01 PM
  4. Need help changing front axle shaft assembly
    By Joop94 in forum Wrangler and CJ
    Last Post: 09-21-2003, 03:58 PM
  5. Need help Front U-joint assembly.
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
Tags for this Thread
