Allen's Offroad
What a deal. Click the image below to order online. Add to cart and don't forget to select your free Gear lube weight.
![](https://www.jeepz.com/forum/images/imported/2019/03/TJLJXJ_Core44_Rear_18-1.png)
Save $250 On G2 Core 44 Complete Assemblies (Mail-In Rebate) Print Form
Free Air Compressor (CKSA12) With Purchase. A $170 Value.
97-06 Wrangler TJ/LJ
Integrated skid plates on lower control arm mount
Heavy-duty 1/4 inch laser cut brackets
Heavy duty 3 inch diameter 5/16 inch DOM tubes
Reinforcing ribs for added strength and protection
Heavy duty forged bearing caps
Spanner nuts for backlash adjustment
Heat-treated aluminum diff cover with cooling fins
Utilizes new generation JK 44 ring & pinion
Gear Ratio: (Choose under options)
Locker: ARB Air Locker
SAE Bearings
35 Spline G2 Chromoly Axles
California Residents: WARNING
Part numbers:
C4TSR456AC5 - REAR 4.56 W/ARB
C4TSR456AC5D - REAR 4.56 W/ARB Disc Brake Kit
C4TSR488AC5 - REAR 4.88 W/ARB
C4TSR488AC5D - REAR 4.88 W/ARB Disc Brake Kit
C4TSR513AC5 - REAR 5.13 W/ARB
C4TSR513AC5D - REAR 5.13 W/ARB Disc Brake Kit
C4TSR538AC5 - REAR 5.38 W/ARB
C4TSR538AC5D - REAR 5.38 W/ARB Disc Brake Kit
SAE Bearings
Part numbers:
