1. seized caliper bolt
    I have a 2002 Grand Cherokee. I have the caliper off, but the bracket that surrounds the rotor is stuck. The two 18 mm bolts on the back are seized. I've broke one cheap socket already. I don't want to use a torch because of all the tubing around. I have sprayed it with PB blaster. Just looking to see if anyone has any ideas. I really don't want to have to drill it out.
    Dec 1999
    Virginia Beach VA
    8,129
    Re: seized caliper bolt
    Do you mean that the caliper bolts are frozen:
    Or are you referring to some other bolts? Post some photos if you can.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    Quote Originally Posted by TerryMason View Post
    No, I'm referring to the bolts that hold the bracket that the caliper screws into. I have the caliper off and the bolts that slide are fine, but the bracket bolts are seized.
    I have managed to get the two bolts out on the drivers side by heating them with a torch and PB blaster.
    I plan on trying the same thing on the passenger side, but I have stripped my ratchet and have to get a new one first. Any ideas you have on getting them free would be great. My biggest worry is stripping them.
  4. Just use breaker bar, get some leverage and it's bound to come off one way or another and if it breaks taps are made for a reason
    Quote Originally Posted by trev98tk View Post
    +1 use a breaker bar and even a cheater bar if necessary, also use an impact socket and it won't crack. Break it loose spray it and work it back and forth. Sometimes there's just heavy amounts of loctite on them.
  1. 80's 14 bolt and matching 10 bolt San Diego
    By Glamissand1 in forum Items for Sale, Trade, or Give Away
    Last Post: 01-14-2011, 06:47 PM
  2. Engine seized!!??
    By rcaldera in forum Wrangler and CJ
    Last Post: 12-16-2010, 09:49 AM
  3. Brake caliper allen bolt size
    By nevpat in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-15-2010, 04:59 PM
  4. Leafs seized?
    By Lucihale in forum Wrangler and CJ
    Last Post: 11-08-2008, 01:46 PM
  5. seized motor
    By burton in forum Wrangler and CJ
    Last Post: 07-12-2004, 11:20 PM
Tags for this Thread
