    3.7L Spark Plugs
    Greetings everyone,
    Finally in the process of changing the spark plugs on my 2006 Sport Liberty with a 3.7L gas engine. The manual says to change them every 30,000 miles but I've waited & now have almost 68,000 miles.
    I went to auto parts store & picked the Champion 3344 platinum plugs for it since I could not read the spec on the data label under the hood due to the rubber seal rubbing it away over time.
    I removed the most forward plug today to check the condition AND to see what the brand/spec was. Turns out it's a NGK ZFR6F 11G. The electrode protrudes farther out than the Champions that I bought, but the store where I bought the new ones (O'Reilly) gives it as one that will work
    Since the Champion seems to be a different heat range than the OE plugs, will they cause any problems if I go ahead & use them?
    Thanks.....
    Almost forgot to mention that the 1st, & only so far, plug I removed was in pretty bad shape. Gap had increased to about 0.070" & the electrode/anode was starting to wear away.
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: 3.7L Spark Plugs
    I would run the correct heat range. I know on hot rods a wrong heat range plug will cause issues.
  1. 2009 3.7L v6 jeep grand cherokee spark plug removal problems.
    By delta1 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-20-2014, 09:12 AM
  2. 06 WK - 4.7L spark plugs
    By hankdz in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-06-2009, 04:48 PM
  3. 06 WK - 4.7L spark plugs
    Last Post: 04-02-2009, 01:47 PM
  4. spark plug wires
    By ChrisCJ7 in forum Wrangler and CJ
  5. Spark Plug Spacing
    By Guest in forum Wrangler and CJ
