2000 jeep cherokee sport
Ya i jear you...Iwasnt sure about the way it was handling and there is def a clunk sometimes around turns...Iwas hoping to a get a little more info about what might be going on with the drive ahaft, if it has play in it, that could be alot of thimgs, they looked it over for what it would need for inspection
With the engine off. Crawl under and grab the driveshaft. Roll it back and forth while looking at the universal joints for play. There should be zero play. Each one with any play should be replaced. If the shaft is bent it needs to be replaced.
