1. Question 2011 Jeep Liberty
    When I leave my Liberty setting at night the battery drains over night. new battery, alternator checks good and as long as i'm driving it starts every time. next morning battery is completely dead. had 2 different shops check it. checked all fuses. removed radio and heated seat fuse.any suggestions? thanks
    Geraldine
    Dec 1999
    Virginia Beach VA
    8,023
    Re: 2011 Jeep Liberty
    Anything electrical that's aftermarket? If you get desperate, you could take a photo of the fuse block (this might make replacing them easier), and perhaps try pulling all the fuses and see if it still happens.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    Feb 2009
    Dayton Ohio Area
    5,306
    2011 Jeep Liberty
    Add pic of battery as connected.
    Is it a union battery?
    Checking for battery draw.
    1.) disconnect negative cable from battery terminal.
    2.) get a digital multi meter (DMM) that cam measure current greater than an amp. At least 10 A. Set the DMM to read current.
    3.) Place a DMM (digital multi meter) from cable to terminal on the negative you disconnected in step 1.
    4.) note the current reading. It should be below 50mA. Start pulling fuses one by one. After each fuse look for the current to drop dramatically. If it does not. Put the fuse back in. Go to the next fuse.
    Find the fuse causing the draw and you found the area to look.
    If not look back at battery main wiring and alternator.
    Radios draw current for memory and lights when powered off. So seeing 20mA drop is normal.
    Do you have anything hard wired to the battery or posts on the fuse box input power?
    Regards,
    JPNinPA
    Never look down on anybody unless you're helping them up. -Jesse Jackson
  1. 2011 Jeep Liberty - heat not working on driver's side
    By theesublimeone in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-03-2019, 10:39 PM
  2. 2011 Liberty Sky-Slider roof wind deflector question
    Last Post: 06-02-2018, 03:32 PM
  3. 2011 jeep liberty sport hand brake
    By yamajj in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-29-2011, 11:29 AM
  4. 2011 Jeep Liberty Hitch Wiring Harness
    By numnutter in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-07-2011, 04:57 PM
  5. 2011 jeep liberty
    By Metalrain300 in forum General Chat
    Last Post: 01-09-2011, 11:20 PM
Tags for this Thread
