1. 2000 jeep hard to start rough idle...
    I have a 2000 Jeep Grand Cherokee 6cyl with the following problems...
    It is hard to start - always
    Rough idle - always
    Knocking or popping sound from engine - intermediate
    Lacks power on acceleration, popping sound - intermediate
    Engine light comes on and goes off
    Recently changed the plugs, dont know what else to check.
    Feb 2009
    Dayton Ohio Area
    5,608
    What mfg and PN on the plugs? What were they gapped at?
    Could you read the codes? I think you might be able to do the key dance.
    And read the codes in the odometer. The procedure is to turn the key from the off position to on position 3 times (without starting the engine) within 5 seconds ending in the on position. The code should show up in the odometer. Too fast or too slow will not work.
    If not take it to or borrow from AZ or OReilly's a code reader.
    Post the codes back up here.
    Could be a number of things.
    Regards,
    JPNinPA
    Never look down on anybody unless you're helping them up. -Jesse Jackson
    Re: 2000 jeep hard to start rough idle...
    The jeep was having this problem before I replaced the plugs. I do not remember the brand of plugs, nor do I remeber what I gapped them at. I used the specs from a Google seach for the gap. Ots been couple months now.
    One person told me it might be a bad Cataylic converter, but I thought the problems would be constance, not off and on.
    Feb 2009
    Dayton Ohio Area
    5,608
    It could be clogged CAT
    If you pull the upstream O2 sensor and symptoms go away its is likely the CAT.
    Feb 2009
    Dayton Ohio Area
    5,608
    Rough start and idle could be dirty air filter, IAC and TB.
    Weak battery.
  1. Hard Start, rough idle, chugs
    By Buffokill in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-13-2020, 12:08 PM
  2. engine will not idle hard to start when warm
    By david roberson in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-02-2011, 01:15 AM
  3. rough start, idle, sudden stalling
    By AKASHAJEEP in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-12-2006, 12:50 PM
  4. 2000 XJ Rough Idle
    By derff96963 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-14-2005, 12:00 AM
  5. 2001 XJ rough idle at start up.
    By trevhutch in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-17-2005, 11:17 PM
Tags for this Thread
