1. Vacuum leak- maybe?
    I have a 2003 Jeep Grand Cherokee Laredo (only 175K miles) that had developed a new problem that I've never seen. I am hoping it's as simple as a vacuum leak and not a transmission that's about to go south.
    It has an automatic transmission, but last week it was acting (in town driving) like I had my foot partially on the (imaginary) clutch. The car would move but acelleration was anemic to the max. When I got home, the first thing I did was to check the ATF level, and it was good. The next day I had to run an errand and it drove fine. In fact, it drove fine for the next few days. Then yesterday, on the freeway (70MPH), it would surge, for lack of a better word. The RPM's were steady but it was like I was tapping on the (imaginary) clutch. I slowed to 65 and the issue lessened a lot. Got to our destination, did our shopping then drove home. No more problems. Today, on the freeway again- no problems.
    So, experts. Transmission or vacuum leak?
    Feb 2009
    Dayton Ohio Area
    6,273
    Re: Vacuum leak- maybe?
    If fluid was full and color correct then clean the TPS and check the transmission output speed sensor.
    [QUOTE=JPNinPA;358401]If fluid was full and color correct then clean the TPS and check the transmission output speed sensor.
    Ok, what is the TPS and how do I find and check the output speed sensor?
    Feb 2009
    Dayton Ohio Area
    6,273
    Vacuum leak- maybe?
    TPS throttle position sensor. #6
    Tps is a voltage dividing resistor. Center pin resistance should vary as you open and close the Throttle Body.
    Sometimes dirt gets in. Fully Opening and closing the throttle body valve a number 20-30 of times can clear it. Some blow air in it. If replacing any sensor use OEM parts.
    Many thanks.
    So, you are ruling out a vacuum, leak?
    Feb 2009
    Dayton Ohio Area
    6,273
    What rpm do you idle at?
  7. #7
    Feb 2009
    Dayton Ohio Area
    6,273
    Vacuum leak- maybe?
    So what did you find?
  1. hvac vacuum leak 97 XJ
    By twinkiedooter in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-20-2015, 09:29 PM
  2. Vacuum Leak on Throttle Body
    By Super6XJ in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-29-2009, 04:33 PM
  3. Vacuum Leak
    By 88YJ6 in forum Wrangler and CJ
    Last Post: 11-07-2007, 01:59 AM
  4. Gross/large Vacuum leak
    By CherokeeGuy42 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-03-2005, 03:05 PM
  5. Vacuum leak
    By xjjunkie in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-24-2005, 03:42 PM
Tags for this Thread
