    2002 Jeep Grand Cherokee Laredo cigarette lighter compartment
    I'm not sure what the compartment that has the cigarette lighter port is called. When I bought my Jeep the area was missing abs replaced by a brown plastic board in its place.
    I need to get a replacement for that panel/console below the AC controls so I can connect a Dash Cam system.
    I need a cigarette lighter panel/compartment - Album on Imgur
    Re: 2002 Jeep Grand Cherokee Laredo cigarette lighter compartment
    Maybe just called panel or lower panel with lighter?
    03 rhd tj
    Quote Originally Posted by superj View Post
    I tried that, everything I can think if doesn't work. I have no clue what that bottom console in center below AC controls is called.
    I really need 1 or 2 12V plug(s) installed.
    I've heard I need a 12v fuse wire connected in between the battery and 12ga wire and maybe have it go to dash fuse compartment so it only has power when car is on. Maybe a power switch.
    But I genuinely need this fixed
    Any help is very appreciated
    Feb 2009
    Dayton Ohio Area
    6,504
    Try here
    B&I(R) - Jeep Grand Cherokee 2002 2D Dash Kit
    Or get part numbers from
    Instrument Panel for 2002 Jeep Grand Cherokee | Mopar Factory Parts
    Call to verify fitment. Many times they want your vin to verify.
    Try here
    Is it just easier to have someone install a 12V outlet?
    From what the previous owner said is that that section has wiring issues or something where if it was messed with more problems happened.
    But I need a dascam and would like a phone charger.
    I could remove the brown (microwave plate) they screwed to it and putty the holes.
    I simply want an outlet so I can get a dashcam Rollin for saftey reasons and insurance claims. Drivers are crazy here, nearly every time I go out there is some drunk/drugged up guy swerving across lines in the city.
    How hard is it to install a cigarette lighter outlet and maybe a couple USB ports?
    I hear you need a wired fuse connected between car battery and main wires and that it needs a on off switch or to also be connected to a fuse box for the dash side so it doesn't stay on when car is off?
    I'm no electrician but hoping someone here has done something similar, and knows how much it costs to get it installed by a place or DIY and where to get that done
    Feb 2009
    Dayton Ohio Area
    6,504
    Oh
    Thought you wanted to replace the missing parts.
    Easy to wire a cig lighter power.
    If you want it off with the key find an open fuse that is on the acc side. Check your owners manual for fuse box(s) and open fuses.
    Run power wire from there to center conductor on cig lighter . Run a wire from the outside body of the cig lighter to ground(body)
    Other opportunity is to replace a acc fuse with one of these for power.
    2002 Jeep Grand Cherokee Laredo cigarette lighter compartment-image1656295077.968952.jpg
    2002 Jeep Grand Cherokee Laredo cigarette lighter compartment-image1656295288.755188.jpg
  7. #7
    yup. super easy to add that stuff in
    03 rhd tj
  1. 2002 Jeep Grand Cherokee Laredo
    By Campbell80 in forum General Chat
    Last Post: 01-28-2017, 11:19 PM
  2. help! I need help figuring out what is wrong with my 2002 jeep grand cherokee laredo
    By howlingwolf23 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-13-2014, 07:51 AM
  3. 2002 grand cherokee laredo special edition quadra trac
    By brandonhays in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-19-2013, 10:49 PM
  4. 2002 Jeep Grand Cherokee Laredo 4.0 Transmission Problems
    By godzilla1 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-20-2012, 05:56 PM
  5. 2000 jeep wrangler se cigarette lighter
    By kearashae in forum Jeep Electronics and Audio
    Last Post: 07-20-2012, 12:16 AM
Tags for this Thread
