    06 commander front differential bushings
    Been away for here for nearly 8 years after trading off TJ. Good to see some familiar names still posting. Just picked up a used commander with a unknown lift ( approximately 3 inchs) with the hard jump and thump of front differential as bushings are completely destroyed.
    Do the lifts for these add any wear on these? I will be checking bearings and cv joints during this repair. Anything else I should be checking while I am there?
    Currently on jeep #5. 2006 Commander
    Feb 2009
    Dayton Ohio Area
    6,599
    Re: 06 commander front differential bushings
    Had to look it ip to see what you were talking about.
    Here is s good video on changing out the bushings.
    Jeep Commander Front Diff Bushing How To - YouTube
    If the geometry of the drive train changes the forces required to transfer torque and horsepower changes too. Unless the drivetrain is lowered as the body is lifted there will be an increase in force on the drivetrain and bushings. But those likely wore out on their own.
    Just wanted to update. This became a 14 hour project ended have to replace left front axle shaft as well. But fixed the thump going into gear and one source of noise.
    Feb 2009
    Dayton Ohio Area
    6,599
    Glad to hear you solved some issues.
  1. How can I tell if my 06 commander has lsd differential?
    By Commando in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-01-2014, 01:35 PM
  2. Front differential
    By gotdirt in forum Wrangler and CJ
    Last Post: 08-06-2011, 11:42 AM
  3. Front Differential Problem
    By BeatUpYJ in forum Wrangler and CJ
    Last Post: 05-12-2005, 12:11 AM
  4. YJ Front Differential Angle
    By BORRONGO in forum Wrangler and CJ
    Last Post: 12-10-2003, 03:57 PM
  5. front differential leak???
    By indiemo in forum Wrangler and CJ
Tags for this Thread
