Thread: CV Boot
    AaronB's Avatar
    AaronB is offline Junior Member
    Oct 2003
    25
    Hi guys
    Youve helped a lot in the past. I need to know how to replace a CV Boot on my 1994 Jeep GrandCherokee 5.2L. There is NOTHING in the Chilton's. I guess maybe it is as simple as disasemling it to the point of removing the boot then working back. Any pointers will help.
    The boot is shredded, and while I drive, there are occasional jolts from that area of the car, it feels like I am hitting a real sharp pothole, but there aren't any on the road! particularly when I am accelerating after turning. Hopefully putting a new boot and lube in there will solve the prob. Thanks for any tips. PS-what exactly is the CV joint, is it the same ast the steering knuckle?
    AaronB
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,383
    I didn't know there was a CV boot on a '94 XJ
    Steering knuckle and CV joint are different. The steering knuckle is on each end of your front axle, it's what the tierod is connected to. Your front driveshaft likely has a double cardan joint, which is often called a CV joint (incorrectly so).
    AaronB's Avatar
    Oct 2003
    25
    I may be incorrect in the lingo. Is an XJ the same as a Grand Cherokee? I had a mechanic tell me the CV boot was bad, and when I inspected it myself, there is a conical rubber boot held on by a clam at either end. It is between the back of the wheel and I guess the outer end of the axle. My "boot" or whatever it is, is ripped apart.
    bchcky's Avatar
    bchcky is offline Senior Member
    Jan 2004
    Boston, MA
    1,390
    Re: Black Wheels?
    Quote Originally Posted by AaronB
    no...bounty he's talking about a zj, not an xj.
    Jack Bauer kills for Jesus: 10
    balloo93's Avatar
    balloo93 is offline Senior Member
    Jun 2002
    101
    You should seriously consider this swap:
    http://www.4x4wire.com/jeep/tech/axle/weak_link/
    Why just fix it, when you can make the front end stronger!
    Nov 2002
    Southern Illinois
    13,383
    I didn't know the ZJ used a CV shaft. Figured they were the same between XJ/ZJ/YJ.
    Good link, I'd recommend you upgrade instead of replacing with stock parts. It's easy to replace the front axle shafts, we'll be here to help with any questions.
  7. #7
    AaronB's Avatar
    Oct 2003
    25
    OK, I am a little slow
    The clunk wasn't in my cv axle, it was my transfer case, which is now totally shredded. I am trying to line up a new one. Mine is model NP249, with 272 gear ratio. There are also 8 numbers in the middle of the tag-serial I am assuming- 5209 7529. I want to make sure I am matching the correct new t-case to my vehicle, in doing that, do I need to worry about the 8 digit number, or just make sure the NP249 and 272 are the same? Thanks
  8. #8
    graewulf's Avatar
    graewulf is offline Senior Member
    Mar 2003
    Manahawkin NJ
    1,316
    ZJ with CV joints? i'm pretty sure its got U-joints at the wheels
    When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!
    1995 Grand Cherokee w/ swaybar disconnects and 30" tires and a 2000 Grand Cherokee stock.
  9. #9
    Nov 2002
    Southern Illinois
    13,383
    Check out the above pic, both CV joints and ujoints were used in the Grand through the years.
  10. #10
    graewulf's Avatar
    Mar 2003
    Manahawkin NJ
    1,316
    guess i'm gonna have to check mine.. its a 95 and feels like u joints when cornering.....
