    choyehgirl's Avatar
    choyehgirl is offline Junior Member
    Jan 2009
    1
    HELP! '04 Liberty won't start. Grinding noise.
    My '04 Jeep Liberty won't start and makes a grinding noise when you try. The noise is similar to a drum roll or to the sound a playing card makes when put in the spokes of a bike wheel. This is out of the blue. It's very cold (for Dallas) this am (about 25-30 degrees) but I don't think that has anything to do with it. It's been cold off and on for a few weeks. Help! Is it the starter? Something I can fix myself?
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Re: HELP! '04 Liberty won't start. Grinding noise.
    Is the NOISe a constant Clicking like noise? and does the engine turn over at all when this happens?
    dbxtr3's Avatar
    dbxtr3 is offline Junior Member
    Sep 2008
    Louisville, KY
    8
    From what you described it sounds like the engine isn't turning over and you are hearing a clicking sound of the starter relay. IF SO, you have a battery that is going bad. The recent stint of cold weather will kill batteries. Extreme weather will kill a cell or two in your battery then it can not supply the voltage to the battery to turn over the motor that when you just here a clicking noise or a baseball card in the spoke sound.
    tricky-1948's Avatar
    tricky-1948 is offline Member
    Jan 2009
    32
    hi m8 have you had the starter motor off ? the sound could be the bend ex spring stuck ? which when you turn the key to start the motor it turns over but does not engage the flywheel,it just hits the teeth of the fly wheel which gives you that sound normally a good clean and replace it at worst a new bend ex or starter motor ? good luck.
    Richard
  1. Liberty 2002 refused to start
    By malagbile in forum Jeep Electronics and Audio
    Last Post: 12-28-2008, 01:50 PM
  2. Grinding noise from front of engine
    By SenorCole86 in forum CJ YJ TJ and JK
    Last Post: 08-20-2006, 07:47 PM
  3. Sqeaking Noise on Start Up
    By cpasciuto in forum CJ YJ TJ and JK
    Last Post: 02-05-2006, 06:32 PM
  4. Metallic Grinding Noise 99 Wrangler??
    By d75angel in forum CJ YJ TJ and JK
  5. Metallic Grinding Noise 99 Wrangler??
    By d75angel in forum General Chat
