1077283
There is a way to adjust the timing on an 87, initial timing that is. But it is pretty much a pain and rarley necessary.
On my 88, what was really acting like timing issues, turned out to be, a combination of things. Plugs, wires, distributor cap, filters, dirty electrical connectors and slightly plugged injectors, with a partially plugged exhaust and a possible loose timing chain.
If your getting a serious cross fire, at mid RPM´s (around 2000) with a steady pedal (moderate vacuum). It may be crossfire, but is probably something else.
One major improvemnet I had, was to clean all the die electric grease out of the distributor pick up plug. really made a noticibale improvement.
A new air filter, was also a major improvement.
You can check your initial timing fairly easily. All you need is an old distributor cap. Cut a hole after the number one electrode in the cap, so you can see the rotor. Set the motor up for TDC, number one cylinder, align the timing marks. The rotor should be past the electrode, with the trailing edge of the rotor about .020 past the electrode. The timing mark for the 4.0 is hard to see, on the inside of the main pulley, I usually move the mark to the outside (chisel) and mark it with nail polish (my daughters not mine :roll: ).
If my explanation is hard to understand, I can try a better explanation.[addsig]
