no spark
manchee
i have a 1988 camanchee truck it has no spark from the coil
replaced coil still no spark
any suggestions would be great. :???:
did you check the ign. fuses? also there is that stupid balist resistor pack thingy on the drivers side inner fender near the head lights, check that out.
i got it started. i disconected the crankshaft postioning sensor and pluged it back in. i also found a wiring harness connection on the drivers side fire wall
that looked kinda melted. took that apart and cleaned all the posts and put it back togeater and it started right up. thanks for your alls help.8)
