Thread: just a thought?
    abe's Avatar
    abe
    abe is offline Senior Member
    Nov 2009
    Sarasota, Florida
    288
    just a thought?
    i have a 97' tj with a Dana 30 front axle. i just bought a new steering linkage tie rod and drag link from rugged ridge. i noticed that i have flat spots on the top of my steering knuckle. wondered if i could bolt the tie rod ends up top instead of down below? kinda like a cheep way to raise up the linkage and get it out of the way. anyone ever done this? can it b done? just a thought? thanks.
    IF IT DON'T FIT FORCE IT. IF IT BREAKS IT NEEDED TO B REPLACED.
    xt master's Avatar
    xt master is offline Senior Member
    Nov 2008
    NE-PA
    1,656
    Re: just a thought?
    I dont think it would work.Looking at the pic where you bolt it on it is more like a cup.If you bolt it with it on top the bolt would be in the cup section and the tie rod.
    bobcat481's Avatar
    bobcat481 is offline Senior Member
    Dec 2009
    Indiana
    530
    Re: just a thought?
    I may be wrong, but I bet they are tapered, forcing you to use it from the bottom up. If they are not tapered, then I don't see why it would hurt.
    Sid1966's Avatar
    Sid1966 is offline Senior Member
    Apr 2009
    Dryden,On,Canada
    150
    Re: just a thought?
    the holes are tapered you would have to taper the holes from the top , depending on the bends in the steering components could cause interference with other components,ie track bar, sway bar links, steering stabilizer.if it is the rugged ridge setup i am not sure if the passenger side can be flipped and still be hooked up,i would take a lot of carefull measurements before you get the knuckles re-tapered
    abe's Avatar
    abe
    Nov 2009
    Sarasota, Florida
    288
    Re: just a thought?
    After doing a little research i found out it can b done. You would have to drill out the hole to 3/4 of an inch to get rid of the taper and then insert these (Jeep Cherokee Wrangler Tie Rod Flip Kit HIGH STEER KIT [J202] - $18.99 : Motomomentum!, Jeep JK vs Toyota FJ the finest in Offroad Parts) some people weld them in some just use loc-tite. not sure if i am going to do it yet but ill let everyone know if i do. I need to weigh the pros and cons.
    Attached Thumbnails Attached Thumbnails just a thought?-highsteerkitbasic.gif
  1. It's just a thought...
    By laxpug19 in forum General Chat
    Last Post: 06-03-2007, 10:22 PM
  2. Never thought to Ask?
    By KrazyJeeper in forum General Chat
    Last Post: 07-24-2006, 04:29 AM
  3. ...Just a thought...
    By Saurian in forum General Chat
    Last Post: 02-18-2004, 05:47 PM
  4. Never thought of this!
    By Desert_Rat in forum CJ YJ TJ and JK
    Last Post: 11-10-2003, 11:04 PM
  5. Just when i thought i've seen everything...
    By Jeeppicus in forum General Chat
