    Quahitis's Avatar
    Quahitis is offline Junior Member
    Aug 2008
    3
    1998 TJ steering issues
    I bought a 98 TJ about a year ago and the steering has also been sloppy. The jeep will wander all over the place, especially on uneven roads. I took it into the shop and they told me all of the steering components looked good to them. Any suggestions? I was thinking about replacing the steering stabilizer but I do not think it will clear up all of the issues. I'm running 33s and have a Rancho Rockcrawler suspension.
    Thanks!
    1998 Wrangler, 4.0L, 5 Speed, 3.5" Rancho Rockcrawler lift, 1" BL, SYE, Dana 30 & Super 35 with 4:10's and ARB Air Lockers, 33" Bridgestone Dueler M/Ts, Warn 8000xi, Air Raid Intake, Onboard Air
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    I would Check to see if the sloppy/ loose steering is evident while it's parked. If the steering has exessive play with the engine not running, I would look into the possible components involved like the tie rod ends, track bar, or ball joints. Another thing that would cause the wandering on the road is the alignment. Caster , toe and camber plays a big role all together on the straight ahead stability and performance in your steering.
  1. CJ-7 Steering column issues
    By VegasCJ7 in forum CJ YJ TJ and JK
    Last Post: 04-06-2010, 01:33 AM
  2. 1998 GC Limited front end issues
    By bre's dad in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-26-2009, 08:46 AM
  3. Steering Issues
    By wontoughcookie in forum CJ YJ TJ and JK
    Last Post: 05-15-2009, 04:31 PM
  4. Steering play on 4.0L XJ 1998
    By Mike1 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-14-2004, 11:43 AM
  5. 258 85cj7 am I having timing issues or valve issues
    By Platsmith in forum CJ YJ TJ and JK
    Last Post: 07-03-2004, 04:26 PM
