    Marv46534's Avatar
    Marv46534 is offline Junior Member
    Oct 2010
    Northwest Indiana
    2
    1995 Jeep YJ Dies and Won't Start
    I have a 1995 Jeep Wrangler YJ with MPFI.
    The problem is it will instantly die on the road, no missing or sputtering, then won't start. Cranks fine. Does start when it is good and ready.
    I thought it was happening when it had been running and was really warm. It would start after maybe 30 minutes. But yesterday it wouldn't start the next morning. After I towed it home, it started right up.
    This has happened 4 or 5 times in the last 2 years. Always in the worst possible place. Otherwise it runs great. Here's what I know.
    Trading fuel pump relay didn't help.
    Jumpered contacts on relay socket and could hear fuel pump working.
    Checked for spark and was good.
    Checked for fuel pressure at tire valve like cap on fuel injector. Seemed ok without a gauge.
    I did have a Datsun pickup years ago that would do the same thing. Turned out to be a small piece of foil floating around in the fuel tank. It had an access cover in the truck bed, and I could see inside. I would hate to have to take my Jeep's tank all the way off.
    My question is could low pressure due to a bad fuel pump cause it to just instantly die? It seems like that would cause sputtering and bucking first. This sounds like ignition, but I don't think so.
    Saddle Tramp's Avatar
    Saddle Tramp is offline Senior Member
    Apr 2009
    Vancouver USA
    612
    Re: 1995 Jeep YJ Dies and Won't Start
    As always with electrical, check your grounds to make sure they aren’t loose or corroded.
    superj's Avatar
    Feb 2010
    texas
    5,754
    dumb idea, thinking of something else
    jfrabat's Avatar
    jfrabat is offline Senior Member
    Dec 2006
    San José, Costa Rica
    1,693
    I would guess a lose connector is your issue. Possible even the battery connector. but since all the other electrical components seem to be working properly (you mentioned spark, fuel pump, etc.), it could also be the ECU, I guess... I would start by checking connections, though (that's free, after all!).
    '94 YJ 2.5L, Sperwinch EPi 9.0, RE 4" Std Lift, Adv. Ad. SYE, Woody Shafts, Alloy Axles, ARB Lockers, 4.88 gears, 62mm TB & Spacer, 165A Alternator, Griffin 3" Aluminum Rad, Taurus e-fan w/ DC Controller, Borla Cat-Back, Flowmaster hiflow cat, PD Ignition, 19# injectors, Adj. FPR (42PSI), MOPAR cam, Safari Snorkel, 33" BFG KM2, 15" AR wheels, Xenon H4 lights, KC Daylighters & Slimlites, Sony sound, Pavement Ends Targa Top, Hanson Front Bumper, JCR Offroad rear, AtoZ Rockers, Rhino lined Tub.
    Marv46534's Avatar
    Oct 2010
    Northwest Indiana
    2
    It looks like I've fixed my problem. As it turned out, sometimes the fuel pump wasn't working. Sometimes the ignition wasn't firing. The key was the check engine light wasn't coming on when it wouldn't start. I found a thread on another forum (jeepforum) that hit the nail on the head. My PCM (computer module) wasn't working right.
    jeepz won't let me paste a link here (haven't been a member long enough), but you should be able to find the thread by searching jeepforum for "91+ Hard or No Start/Long cranks in the cold explained" for the cause and "Crash Course In Brain Surgery Replacing Capacitors On ECU" for the fix.
    It was a real pain working on the circuit board, and I've been an electronics technician for 30 years. It really isn't designed to be taken apart and fixed. It's encased in some kind of rubber compound to protect it from the elements. So, it's a throwaway. Trouble is a new one costs $650 or more. Used ones are hard to find, because there are so many types. There were several types for just my 1995 YJ. It has to match the engine, transmission, etc. I think PCM's after 96 or 97 are programmable, so the same one can be used for many models.
    Anyway, I followed the instructions. Bought 3 capacitors at Radio Shack part # 272-1029 for $1.29 each. These are 220uf 35wvdc capacitors. Took about an hour to replace them once I had the module on my work bench. I was doubtful this would work. But much to my surprise, my YJ fired right up and hasn't failed since.
    2 of the capacitors I took out were swollen and leaking. Electrolytic capacitors do have a life in hours. Someone on the above thread said this particular one is only designed to last 10 years. I'm not sure the Radio Shack ones will last that long, but the price is right.
    BTW, I used a silicon dielectric compound to seal the openings I made on the circuit board. It never hardens and is designed for electrical connections.
    Quote Originally Posted by Marv46534 View Post
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    That's good to know.
  1. 1994 Jeep Grand Cherokee dies in reverse
    By trxus in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-31-2009, 08:47 PM
  2. 87 Yj Jeep dies under power
    By jdavidson in forum CJ YJ TJ and JK
    Last Post: 08-01-2009, 10:51 AM
  3. Jeep dies when any lights come on
    By iraq_vet_x2 in forum CJ YJ TJ and JK
    Last Post: 02-26-2009, 11:46 PM
  4. jeep idles then dies
    By blown XJ in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-29-2007, 10:57 AM
  5. 1995 Jeep YJ for sale
    By ah_too_bad in forum Items for Sale, Trade, or Give Away
    Last Post: 04-21-2004, 05:10 PM
Tags for this Thread
