Thread: Next Tires
01-09-2017, 04:51 PM #1
Next Tires
Hi everyone, this is my first post on the Jeepz forum. I've got an 01 TJ with a 4" suspension lift and it's about time for new tires. I currently have Mickey Thompson MTZ 33's but wanted to try something different. Anyone ran the Cooper Discoverer STT Pro's? Or other recommendations? Thanks ahead of time for the sage advice!
Jeff
01-09-2017, 07:38 PM #2
Re: Next Tires
Here is one with 36x13.5 x15
Sent from my D6708 using Jeepz.com mobile app
01-09-2017, 07:49 PM #3
Re: Next Tires
He said those tires measure 36.5 dia or so
01-09-2017, 08:01 PM #4
Re: Next Tires
Or are you staying with current size
Sent from my SGP561 using Jeepz.com mobile app
01-09-2017, 08:14 PM #5
Re: Next Tires
Just today i received my Nitto terra grappler's in 305 /70 R16. The reviews were great but will see once mounted. My brother runs Cooper tires on his Jeeps.....yes JEEPS. Lol
01-09-2017, 08:41 PM #6
01-09-2017, 09:21 PM #7
Re: Next Tires
I know😎👍👍
01-09-2017, 09:27 PM #8
Re: Next Tires
BFG KM2. Good all round offroad tire.
01-09-2017, 09:56 PM Thread Starter #9
Re: Next Tires
Yeah been looking at the Nittos and reading reviews. I've seen them on a guys truck at work but no Jeeps
01-09-2017, 09:57 PM Thread Starter #10
Re: Next Tires
Those get great reviews, thanks Jeepergeo!
01-09-2017, 10:31 PM #11
Re: Next Tires
Bag's are good. Get your tire with higher land rating
01-10-2017, 09:22 AM #12
Re: Next Tires
01-11-2017, 12:24 AM #13
Re: Next Tires
I'm probably going to use them on my diesel except I'm going to get the E rated load range
01-11-2017, 03:09 PM Thread Starter #14
Re: Next Tires
The load range I'm seeing is 2205. Is there something else I should be looking for? Recommended?
01-11-2017, 07:39 PM Thread Starter #15
Re: Next Tires
Nevermind, now I see it. Most of the tires I'm looking at have a load range of "C"
01-11-2017, 07:47 PM #16
Re: Next Tires
E is 10 ply. There is also a D rating
01-11-2017, 07:51 PM #17
Re: Next Tires
I need E because I tow q big boat. The side walla are very stiff and keeps the wallowing side to side to a minimum
01-12-2017, 01:32 PM #18
Re: Next Tires
I agree with 78CJ71TON. The caveat is that when you are not Towing that heavy load, those heavy-duty tires are going to ride real hard if left aired up to factory recommended pressure settings for that jeep. Running lower pressures in higher capacity tires when NOT towing will definitely help soften up the ride but it will also tend to make the tires wear unevenly (more wear over time near the edges and less near the center of the treads). Under-inflated will also tend to exasperate that sidewall flex you're trying to avoid in the first place... Catch-22...:-(
RR
Sent from my Z970 using Tapatalk
01-12-2017, 03:13 PM #19
Re: Next Tires
C or D
01-12-2017, 03:21 PM #20
Re: Next Tires
I'm running the 37x12.5 x 16.5 good year military OZ tires from the humvee. They are radials and 9 ply. I run about 25 lbs of air on the road right now. They can get really stiff when you add air. But they are Tuff as nails and so far wear seems good. Bead locks would be good with them at around 5 to 10lbs. once I get more crap bolted on my rig the extra weight will help compress the tires
tires
By gafire in forum General ChatReplies: 2Last Post: 06-30-2011, 09:30 PM -
Mud tires
By Wcrsi1 in forum Texas Jeep ForumReplies: 7Last Post: 12-06-2010, 10:04 AM -
tires
By kreatos909 in forum Cherokee, Commander, Wagoneer and LibertyReplies: 4Last Post: 11-17-2010, 04:45 PM -
tires,rim,
By lambo in forum Cherokee, Commander, Wagoneer and LibertyReplies: 0Last Post: 08-27-2010, 07:56 PM -
Tires
By steelerman in forum CJ YJ TJ and JKReplies: 2Last Post: 07-20-2003, 07:00 PM
