    Rj_bigdaddy's Avatar
    Rj_bigdaddy is offline Junior Member
    May 2017
    4
    1995 yj 4.3 swap..issues with slave cylinder
    Hey guys. New to the forum. So I have a 1995 yj. I just got done swapping over to a 4.3L motor. I got shorty headers figuring it would be a better flow with the new exhaust. After I got the passenger side done I moved on to the drivers side. Wellllll!!!! I have a issue. The clutch slave is in my way. I'm stuck. I looked up Novak to see what mods they might have but there site does not explain well enough if this is going to solve my issue. I called them. Not much help. I'm not sure if I should try to heat up the end of the header and bent it out to clear it. Or idk. Any advice and pics would help a lot. Please and thank you
    Attached Thumbnails Attached Thumbnails 1995 yj 4.3 swap..issues with slave cylinder-img_1923.jpg
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,358
    Re: 1995 yj 4.3 swap..issues with slave cylinder
    Why is the clutch slave mounted there and not in the firewall? Is that the OEM location?
    May 2017
    4
    Yes it's the oem location. It can't go anywhere else
    Nov 2002
    Southern Illinois
    13,358
    I had a '95 YJ and it looked nothing like that. Those aren't even factory bolts holding the clutch slave. The clutch slave should be mounted into the bellhousing.
    Nov 2002
    Southern Illinois
    13,358
    You're going to need a center dump manifold on that side.
    May 2017
    4
    I just made a new bracket instead.
  1. Slave Cylinder
    By JB88Cherokee in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-31-2012, 06:56 PM
  2. slave cylinder
    By TheOKCAggie in forum CJ YJ TJ and JK
    Last Post: 08-20-2011, 10:33 PM
  3. Slave Cylinder on 94 YJ 2.5L w/4 spd
    By simontonbill in forum CJ YJ TJ and JK
    Last Post: 10-26-2009, 11:52 PM
  4. slave cylinder
    By Ragtopman in forum CJ YJ TJ and JK
    Last Post: 11-07-2006, 06:21 PM
  5. Slave cylinder
    By odjeep in forum CJ YJ TJ and JK
    Last Post: 01-19-2004, 11:28 PM
