Thread: 4x4 problems
    japish's Avatar
    japish is offline Junior Member
    Nov 2003
    2
    Haaving problems with my 89 yj....... i put it in 4x4 and the front drive shaft turns but the alxe won't engauge.. does some one have a diagram i can print off?
    Tug-n-pull's Avatar
    Tug-n-pull is offline Senior Member
    Oct 2002
    East Tennessee
    5,149
    4x4 problems
    Check your vacuume lines going to the front axel on the passenger side. This is causeing the front hubs to not lock in and pull. If this is the cause I can show you how to be a cable posi lock system to make it a better than factory system. Check the lines I bet one has popped off. Tug
    J:UN's Avatar
    J:UN is offline Member
    Sep 2003
    Denver, CO
    71
    Tug
    Word has it you know a "do it yourself" way of doing this?
    Jeeps don\'t break...they just give you opportunities to upgrade!!
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    Pull the two vacuum lines from the front axle disconnect. With the jeep running and chocked, have somebody shift from 2wd to 4wd and back. Strong vacuum should switch back and forth between the two ports. This should help you find the problem.
    japish's Avatar
    Nov 2003
    2
    thanks guys all it was was the red manifold vacum.. you guys are a big hepl thanks agian.
    Nov 2002
    Southern Illinois
    13,425
    Cool, glad it was a simple fix.
  7. #7
    L33TJ33P's Avatar
    L33TJ33P is offline Senior Member
    Mar 2003
    Atlanta, GA
    1,653
    Oops wrong thread
  8. #8
    LtFuzz's Avatar
    LtFuzz is offline Member
    Apr 2003
    61
    is the vaccum the same reason that my 4WD light doesnt turn on...and yes i checked the bulb
  9. #9
    Snitty's Avatar
    Snitty is offline Senior Member
    Nov 2002
    Olean, NY
    5,646
    that will cause the light not to come on
    bounty.. are those drag slicks on that wrangler in the diagram?
    93 YJ 4.0
  10. #10
    Nov 2002
    Southern Illinois
    13,425
    LtFuzz, that will keep the light from coming on. Chances are the pass. side axle shaft in front is not engaging, meaning no 4wd for you until it's fixed. It's a pretty easy system to troubleshoot once you're familiar with it, let me know if you need any help.
    Snitty, those are MT DOT legal drag tires. If I had done the diagram, they'd be shorter
  11. #11
    Snitty's Avatar
    Nov 2002
    Olean, NY
    5,646
    and 10 slots in the grill? for cooling puposes i would assume... that thing must be a dragstrip monster
    93 YJ 4.0
  12. #12
    Shep's Avatar
    Shep is offline Junior Member
    Feb 2003
    12
    Well im sure glad i found this post. Ive just finish changing the clutch and somehow managed to stop 4wd engaging when i took out the trans. I thought it might me that i'd disconected one of the vacuum lines and reading above it turned out to be the red one as well which apparently goes to the manifold. Only problem is im not sure if im just being really blind but i cant seem to find exactely where it connects. I dont suppose anyone could kind of direct me in the right location can they??
  13. #13
    KletusJeeps's Avatar
    KletusJeeps is offline Senior Member
    Jul 2003
    126
    Tug... please do tell...
    KLETUS
  14. #14
    J:UN's Avatar
    Sep 2003
    Denver, CO
    71
    He's being secretive....I think we need top secret clearance er something
  15. #15
    Tug-n-pull's Avatar
    Oct 2002
    East Tennessee
    5,149
    If you were speaking of a home brew cable front diff disco loo here. tug
    http://home.earthlink.net/~stevenschreiber/cabledis.htm
