principalb
75 cj5 witha straight 6. OK so I am wondering where the red wire from the double plug on the alternator goes? There are two wires one is black and one is red going to two tabs on the alternator. The black goes back the fuse box. I got that. The red goes?? I put it on the post on the alternator but that causes a drain on the battery and the alt gets hot. with or without that red wire the alt is still charging the system. I have a yellow wire coming from the starter coil to the post on the alt that seems to be correct. Any thoughts? Is this a wire from days of an external regulator and now that the alt has one built in this is no longer needed? Help I cant use my jeep till this is fixed and it is my last maintenance item on the vehicle since I bought it and Im tired of dumping uneeded cash into the car! HEEEELLLLLP
