Hello Jeepers.
My jeep is giving me nightmares, i have been trying to fix it for 2 years no hope yet. anyway i will state my problems here i hope you will help me, they are too much but meh please help.
1- my jeep fuel cusumption is 7MPG YES 7MPG, NO i'm not LYING. i tried filling the car till F and drove around till it reached E and the result is 155.343M (250KM) which is 7MPG.
2- my jeep is emitting white smoke from the exhaust, while idling there is no smoke, while going slowly there is no smoke, only on kick down or while pushing the pedal hard a white smoke appears and goes away after a little.
3- my jeep dies while going uphill, what ever my car speed is when i reach an uphill my jeep starts to die till it reach the 2nd shift. for example: if i'm going 160 on a highway then an uphill appears the jeep wont go fast keeps going slow it even if i push the pedal it keeps dying till it reachs the 2nd shift then it takes it force back and when it reachs 3rd shift it dies again, i don't know if you got the idea.
4- VERY HIGH OIL CONSUMPTION, i add ~ 1Killo of oil each month!.
what i did:
1- Replaced the fuel filter.
2- Replaced the air filter.
3- checked the catalytic converters.
4- made a compression test the jeep result on all the 6 spark plugs is 145PSI
5- checked transmission system
6- checked the front and rear differential
7- checked all the seals (oil seals) for any leak!.
8- Replaced Spark plugs brought original mopar spark plugs.
9- Fuel pump is in good state compression test result is 50PSI.
10 - Cleaned the IAC and the TB.
NOTE: Check engine light is off.
Thank you, your help is really appreciated.
Best Regards!
what i did:
Best Regards!
