Been doing a handful of the annual maintenance things as well as replace the rear upper shock mounts on  my O6 TJ (who ever came up with that factory design should be castrated)    When I finished up I did something I do fairly regularly, and wondered if anyone else does it:   Since I generally end up removing my wheels a couple limes every year. Every 2-3 years I chase the threads on my Lug bolts and nuts with the factory spec tap and die. I regularly add a spot of antiseize to the bolts every time I pull the  wheels, But with heat and time the graphite and petroleum lubricant does harden. So I just thread the die on the bolt Flat side first (not tapered unless the threads need to be recut due to serious damage) My die is hex shaped so I can use a socket and ratchet to run it down all the way and back off.  spray the lug with a light oil after chasing it, to rinse off debris cut out of the threads and to protect the fresh steel that may be exposed from rusting. The nuts will be a more difficult issue, especially if you don't have a plug or bottoming tap as they are very easy to cross thread, so take your time with them. Again when done spray them out to remove the crud, asn spray the taps and die between the lugs and nuts. Add a smear of antiseize before running thee cleaned nuts down the lug bolts all the way and back them off and you are all set. Properly torques the wont loosen up, but they wont get stuck either. there is nothing worse than having to change a tire on the trail when you cant get it off the vehicle. This trick prevents that issue.   And since we are on the subject. How many of you have knocked a tire off the rim while on the trail? all you need is a match and a can of starting fluid to put it on.  Lay the tire while on the rim, flat on a non flammable surface such as bare dirt  Spray some starting fluid into the tire's interior, and spray a fuse line over the tire's ( think road runner and the coyote) side wall from the interior over the bead and down the side on to the ground for a foot or so, do it fast so it doesnt dissipate. now throw a lit match at the "fuse line" of fluid. turn  your back and cover your ears. When the ether in the tire ignites, it will generate a massive amount of air pressure momentarily, and seat the bead in place. BUT when it hits the rim, it will cause the rim to ring like a bell, and it will be very loud.  Try this at home some time. keep the pets and kids clear, this is a free running generation of a high volume of hot air. Ive known and used this technique from the early seventies when I was dirt racing as a kid.  Before you ask or comment, yes it can be dangerous, don't make a lake of ether in the tire,,, However once the tire seats the fire will smother itself right out due to the fact that it rapidly uses all the oxygen inside the tire.   When the tire is seated on the rim, air back up. and you are good to go, but I's recommend a little more air this time, and make sure all four tires are at the same level.
