    Branjmb's Avatar
    Branjmb is offline Member
    Aug 2010
    66
    *which* year/model ford taurus fan did you use in your jeep?
    I want to do the ford taurus electric fan mod, but i want to make sure i get the right one.
    I have a dual-fan from a taurus, but unsure if it will fit (will be trying out tomorrow). Otherwise, what have you all used? I have never seen a dual fan in your pics so I think i need to get a different kind.
    thoughts?
    Jeep Wrangler '92 YJ
    kingmega's Avatar
    kingmega is offline Senior Member
    Jun 2011
    michigan city IN
    164
    Re: *which* year/model ford taurus fan did you use in your jeep?
    really just 95 and older
    The best part's are the one's the wife never know's about
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    Mid 90's from the 3.8L engine. It's a single fan with 3 wires.
    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,322
    On my '78 CJ5 (V I used the '98 Ford Coutour/Merc Mystique dual fan it it was practically a perfect fit. In the process I heard from some that mentioned the twin fans had a higher flow rate, but I don't know about that, but it has the same three wire hookup, unless you get elaborate about relays and soforth.
    *which* year/model ford taurus fan did you use in your jeep?-16685d1365775227-contour-fan-upgrade-need-step-step-please-8641968425_382c6b1147_h.jpg
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
    Nov 2002
    Southern Illinois
    13,425
    Good pic, but 6yr old post.
    Skulljeep683's Avatar
    Skulljeep683 is offline Senior Member
    Feb 2012
    Bridgeview, Illinois, United States
    120
    I grabbed mine from a liberty. Then grabbed a wiring harness that goes to the fuse block and then relayed it in the block using an unused port and tied it into the temp sensor. Don't have to have to do anything for a total of 100 bucks in parts using a used fan from an 03 liberty.
    Honesty is my policy
  1. Wheel interchangability year/model
    By rremr1964 in forum CJ YJ TJ and JK
    Last Post: 03-02-2010, 09:54 PM
  2. Buying a 20-year old model
    By Kelley.jarman in forum General Chat
    Last Post: 07-25-2008, 06:44 PM
  3. Ford Taurus electric fan in YJ
    By JeepcrewX5 in forum Jeep Performance
    Last Post: 12-27-2006, 09:14 AM
  4. What's your favorite model and year Jeep?
    By TwistedCU in forum General Chat
    Last Post: 05-11-2004, 09:30 PM
  5. '03 model year TJ factory order???
    By thejafe in forum CJ YJ TJ and JK
    Last Post: 10-17-2003, 07:57 PM
