trans
ronnieb
97' wrangler 4.OL 5speed hard to shift, untill the rpms slow down,what can we do, & how much? thanks.:( :???:
Try changing the fluid first and see if that takes care of the problem. Most of the guys here likes the Redline fluid. I recently switched to the Royal purple and seems to work great.
Neither are too expensive if you do the work yourself; expensive if you pay someone to do it. I vote do it yourself and save/learn. Either way the transmission has to come out. I’m thinking you might be needing a clutch rebuild anyway…. You’ll know once you get everything on the floor.
