I have an engine code P0138 it deals with 02 Sensor Bank 1 Sensor 2 I just need to know which 02 Sensor that is so I can test it to see if it is good? Any knowledge of which one it is or a pic would help out a lot.
sensor 2 is the downstream one which is the one farthest away from the engine, after your cat. should be around your transfer case i would imagine. and USUALLY if one is gone then the other sensor aint far behind. hope this helps
