25 Gallon Gas Tank from GenRight Off Road
GenRight Off Road
This is the New 25 Gallon GenRight Crawler™ Gas Tank to fit a Jeep JK (2007 - Current). It is specifically designed to REMOVE the factory tank from under the middle of the vehicle so you can run true Rock Crawling triangulated 4 link rear suspension (yes, no trac bar!).
This tank follows in a line of innovative and trail proven, top quality gas tanks produced by GenRight.
The tank assembly is relocated to the rear muffler area and mounts in a way that still works with your factory gas filler. It even re-uses your factory fuel pump module so can work with all your factory emissions equipment so you won't get any check engine light or have computer issues.
Aluminum Skid:
Steel Skid:
Uses an Aeromotive Fuel Pump (available separately):
Questions? Check here: GenRight offers the best prices and customer service for JK 25 Gal Gas Tank, Rear Tank Only to be purchased online 24/7. or give us a call.
And don't forget to use code GRCHRISH to save 10% on your order. Exclusions apply.
