leadfooted
This Jeep CJ7 took 9 years and over $25k to get to its current state.
It was a goal to build a Jeep and do the Rubicon. I have succeeded in both and went a little overboard in the process. Since completing the trip in 2006 the Jeep has not been off-road and I feel it's time to let someone else enjoy it. It will not pass smog in its current state, but it could pass with less than $500 in parts and labor as it was originally titled as a V8 Jeep. I have it titled in TX as I'm currently retiring from the military, so it will be sold as-is.
FRAME
Cleaned and undercoated.
BODY
New Steel body tub
Undercoated
Durabak lined interior
Modified for CJ style defroster thru windshield
2’ Body lift
Energy Suspension body bushings
AXLES
Front- Currie 9†axle, 4.11 gears, Detroit locker, Warn alloy shafts, CTM U-joints, Warn Premium hubs, Performance wheel spacers.
Rear- 1984 4cyl CJ7 AMC 20 axle, 4.10 gears, lock-right, and 1-piece alloy axle kit
WHEELS
5 Super Swamper TSL/SX 33x15.50-15LT (Siped)
15x10 aluminum wheels
SUSPENSION
4†Pro-Comp lift kit
F/R Currie shackles (Front Tow)/spring hangers
U-bolt skid plates.
STEERING
AGR Super Box 1 steering box and Super Pump
Currie Steering brace
Engine
AMC 360 Premium rebuilt long block
HD 4 row radiator for automatic transmission
Elelbrock Performer intake manifold, 1406 Carburetor with Off-road needle and seat, and Valve covers
Stock exhaust manifolds
ALL smog equip new
Carter fuel pump
ELECTRICAL
Painless Wiring full replacement harness
FAL dual electric radiator fans
Jacobs and stock ignitions
Wrangler Power Products Dual Optima battery tray kit
Yellow and Blue top Optima batteries
Switches for; Rear brake lights, Windshield lights, Other lights, Rear defroster, Rear wiper.
Warn 9000lb winch with winching accessory kit
2 Explorer Pro-Comp 130 windshield mount lights
TRANSMISSION
Rebuilt 1984 Wagoneer 727
Alison torque converter
B&M cooler
B&M ratchet shifter
TRANSFERCASE
Dana 300 with Currie twin stick
Klune-V David 4-1 Extreme Underdrive
FUEL
Custom Trailquest 12 gauge steel 23 gallon tank with welded 12 gauge steel skidplate, CJ mount, YJ sending unit, YJ side(Driver) filler
Stainless steel fuel lines engine to tank
INTERIOR
Denim black Trail max seats with fabric insert
Wesco Custom Jeep seatbelts
Rear fold and tumble seat
Tuffy Overhead dual security console
Tuffy Maximum storage security trunk
Tilt steering column
Grant steering wheel
Currie Aluminum dash knob set
GAUGES
New CJ speedometer
Stewart Warner Gauges; Tachometer, Mechanical Water Temp, Mechanical Oil Pressure, Amps, and Transmission Temp.
EXTERIOR
DuPont IMRON F-14 grey paint
Currie Rocker panel guards
YJ Xenon fender flares
1995 YJ Hard Top with rear defrost and wiper
Full doors
Half doors
Bikini top
Wind jammer
Tonneau cover
Custom Front bumper with winch guard
Custom rear tire carrier bumper
OTHER/CUSTOM by Arabia’s OverKill Jeep Fabrication
Crossmember/skidplate, flat with bottom of frame, with pillow block for dual front driveshaft to accommodate Transmission to DS clearance.
Frame side mounts of engine mounts raised 1.5 inches. Comes with everything I have for Jeeps or 4 wheeling.
Serious buyers
Price of $12,000
Thanks for looking
FRAME
BODY
New Steel body tub
Undercoated
2’ Body lift
AXLES
WHEELS
SUSPENSION
4†Pro-Comp lift kit
U-bolt skid plates.
STEERING
Engine
ALL smog equip new
Carter fuel pump
ELECTRICAL
TRANSMISSION
B&M cooler
B&M ratchet shifter
TRANSFERCASE
FUEL
INTERIOR
GAUGES
New CJ speedometer
EXTERIOR
Full doors
Half doors
Bikini top
Wind jammer
Tonneau cover
Serious buyers
Price of $12,000
Thanks for looking
