dingus
i paid like 4 bucks for this, so you'd better enjoy it. it also has some diagrams but i'm too lazy to post them now... maybe later.
Here is a copy of your transaction:
Message: for jeep cherokee limited (1990)
alarm wiring instructions and directions
ALARMTEK AUTO SECURITY / WIREWERX.com
Assumes No Liability/Responsibility
For Any Information That Is Found To
Be Unreliable, Or Incorrect.
We Strive To Be As Up To Date
And Accurate As Possible,
But Mistakes Can & Do Occur.
The Following Wiring Chart Of Your
Requested Vehicle, Is To Be Used As
An Installation Guide. Errors Can Happen
From Time To Time, So, Please Meter
ALL Connections BEFORE Completing
The Wire Connection.
NOTE:
USE THE FOLLOWING WIRE CONTACT COLORS,
LOCATIONS AND, POLARITY INFORMATION
IN CONJUNCTION WITH YOUR ALARM/REMOTESTART
OR KEYLESS ENTRY SYSTEM INSTALLATION MANUAL,
TO COMPLETE YOUR PROJECTS!
(We Do Not Supply Individual Manufacturers Manuals!)
JEEP CHEROKEE 2DR 4DR UTILITY
2WD 4WD LTD 1990
Alarm Notes Wiring Location
Constant Power : RED IGNITION SWITCH HARNESS
Ignition Power : YEL IGNITION SWITCH HARNESS
Starter Kill : DK.GRN IGNITION SWITCH HARNESS
Door Trigger : BLK (-) DRIVERS PIN SWITCH
Trunk Trigger : BLK (-) AT REAR LIGHT
Parking Lamp : DK.BLU AT LIGHT SWITCH
Power Lock : WHT****
Power Unlock : DK.GRN ****
****DRIVER'S KICK PANEL 5 WIRE REVERSE POLARITY DOOR LOCKS
WITH OEM KEYLESS LT.GRN & TAN PASS KICK POSITIVE TRIGGER DOOR LOCKS
SEE DIAGRAMS AT www.RELAYHELP.COM
Remote Start Wiring Location
Starter Wire : DK.GRN IGNITION SWITCH HARNESS
Tach Sensor : GRN (-) AT COIL
Ignition (1) : YEL IGNITION SWITCH HARNESS
Accessory : BRN IGNITION SWITCH HARNESS
Brake Switch : WHT AT BRAKE SWITCH
Horn (Relay) : BLK (-) AT STEERING COLUMN
Radio Specifications
Type : SHAFT
Depth : 7 3/4"
Kit : YES
Antenna Information
Type : STAND/POWER
Radio Notes *
Memory : RED/WHT
Ignition Pwr : VIO/ORN
Ground : BLK
Dimmer : ORG/BLK
Power Ant. : GRY
Front Speakers *
Kit : FACTORY GRILL
RF(+) : WHT
RF(-) : BLK
LF(+) : GRN
LF(-) : BLK/WHT
Rear Speakers *
Kit : FACTORY GRILL
RR(+) : WHT/BLK
RR(-) : BRN
LR(+) : GRN/WHT
LR(-) : BRN/WHT
TEK NOTE!
When installing remote start, use the BATTERY as your constant source of power.
This will save on the older nature of the wiring harnesses,
and prevent any undue feedback. You are running a heat risk
under the dash in these vehicles, and by routing the 30amp drain
that the remote starter uses, the battery is your best solution
See Relay wiring diagrams for many applications
including: DOOR LOCKS STARTER KILL, TRUNK POP ETC..
@ www.RELAYHELP.COM
FOR INSTALLATION TIPS/NOTES/DIAGRAMS AND TUTORIALS
GO TO www.MRINSTALL.com (Very Helpfull!)
DONE!
* Always use a digital voltage meter to verify wires !
If you do not use a computer safe test probe in
todays complex vehicles, you can do serious damage
to the onboard computer system!
FOR TIPS, TRICKS, RELAY APPLICATIONS,
AND MORE, JUST GO TO OUR MAIN PAGES!
( These pages will come in VERY HANDY! )
www.ALARMTEK.us
www.ARMACAR.com
www.CARALARMz.com
(QUICKSHOP @ ALARMTEK!)
www.CARALARMCITY.com
www.MRINSTALL.com
www.INSTALLBAY.com
www.RELAYHELP.com
www.WIRINGCHARTS.com
www.ALARMDOMAIN.com
www.INSTALLHELP.com
Get more wiring help-
method tips-
door lock-related info
and 1 on 1 installation
assistance at:
WARNING!!!!
Installing a remote starter on
ANY vehicle with a manual transmission
is DANGEROUS and is NOT advised!
Thank You For Using The WIREWERX!
has taken reasonable steps to insure the
above information is accurate,
but offers no warranty, either expressed or implied
of the above wiring information.
NOTE:
2WD 4WD LTD 1990
Type : SHAFT
Depth : 7 3/4"
Kit : YES
Antenna Information
Type : STAND/POWER
Radio Notes *
Memory : RED/WHT
Ground : BLK
Dimmer : ORG/BLK
Power Ant. : GRY
Front Speakers *
Kit : FACTORY GRILL
RF(+) : WHT
RF(-) : BLK
LF(+) : GRN
LF(-) : BLK/WHT
Rear Speakers *
Kit : FACTORY GRILL
RR(+) : WHT/BLK
RR(-) : BRN
LR(+) : GRN/WHT
LR(-) : BRN/WHT
TEK NOTE!
@ www.RELAYHELP.COM
DONE!
www.ALARMTEK.us
www.ARMACAR.com
www.CARALARMz.com
www.MRINSTALL.com
www.INSTALLBAY.com
www.RELAYHELP.com
www.ALARMDOMAIN.com
www.INSTALLHELP.com
method tips-
assistance at:
WARNING!!!!
