CJ7 gas tank replacement
GaryMB
Well I'm not too keen on feeding my new stroker (yes, I decided to stroke it) with gas from a 21 year old tank that plugged up fuel filters left and right with the old motor. I believe that it is only a 15 gallon tank, and I'm thinking of upgrading to a larger tank. Any suggestions? I noticed that 4 wheel drive hardware has a 22 or so gallon polyeurethane tank for two hundred something. Is this a good route to go, or is there a cheaper way to stuffing a fresh tank under the Jeep? Also, will ground clearance be an issue with such a large tank?
Thats the way I am going with my CJ project, 20 gallon plastic tank.
Fantasy Football Time!!
Poly tanks are great. I also recommend that route.
Make a sturdy skid for it and you probably won't have to touch it again for a very long time.
