CJ7 What Vacuum Hoses do I need to have hooked up
mmajeeper
I have a 84 Cj7 and just swapped engines(Inline 6) What vacuum hoses do i NEED to have hooked up for it to run properly?
Any help is appreciated
Adam[addsig]
1049239
if you give the engine breathing/pcv valve/ and hook up distributor vacumn, and vacumn to E.G.R. valve you should be able to run.[addsig]
1049293
Don't forget your power brake booster...able to run and able to stop. There are a bunch of lines you don't really need but like jeepmastr1 said PVC, distributor, EGR should be your main concern to get it running.[addsig]
