So with all those useless degrees (except spelling) maybe you can explain how the air gets mixed better with the fuel - when there isn't any fuel present?
that is the point.  i know its not getting mixed any better where as if i have not done this type of work,  or had this type of education,  i might not have known.  that is why i think if people are going to say that this thing works,  they need to explain it alot more.
i am saying it won;t work on mpi or direct injection vehicles because of the same reasoning you are using,  no fuel is in the air stream yet so you will have no better mixture then before.
also,  on your hot air entering the filter.
if you run an open element filter to the engine bay (like a lot of people do)  you are going to be sucking in hot air while idling.  say at the stop light or whatever.  like mentioned already,  hot air has less oxygen molecules so you are going to have less power because less air= blah blah,  you know.  anyways,  once you are moving you are going to be getting cooler air,  like if you had your filter enclosed with a tube from the outside.  its just when you are stopped and the ambient air temps rise from no circulation that you are going to get hot air but that applies to an enclosed filter with w tube to the outside because there is this problem called heat soak.  your filter enclosure will get hot as time passes from being in that stagnate non moving air and then you are back to sucking hot air.
anyways,  there was a very good explanation a bit lower on the spacers and how they affect a mpi or direction motor because of hte O2 sensor.
now we are getting to the meat and potatoes (so to speak) of what is actually going on in the intake and what the spacer actually does.  it moves the hp and torque up the rpm range,  not actually increases it, by lengthening the runners of the intake.  the same happens with shorty and long tube headers.  you can change your hp and torque range by using different types of headers.
i like this part of the threads.  the technical part.  i loved the different powerplant courses and the different theory courses.  very interesting information.  then, ending up racing bmws,  it helped in deciding what i wanted to do  to the engine to reach my goals efficiently
