GenRight Off Road
The following items have no structural or functional issues and only being reduced due to slight blemish.
Jeep JK Front Winch Bumper Stubby, STEEL (3 Slot)
SKU FBB8000-3
SAVE $150 on this bumper!
Hurry quantity is Limited!
This is the most affordable Front Bumper for the Jeep JK from GenRight Off Road!
We call this model our "Stubby" front bumper for Jeep Wrangler JK because of it's small size and simple design.
Our high quality, high clearance Stubby type front bumper with a recessed winch mount. It is perfect for the guy who
wants a clean and simple front bumper for their Jeep. The design incorporates the winch mount to keep the winch lower
than most other bumpers to allow for optimal air flow to the radiator.
Other FEATURES Include:
-Fits the 2 door and 4 door Jeep JK.
-Compact design fits tight to the frame and wraps around each side.
-Works with Antirock type sway bars (or the factory sway bar).
-8 bolt mounting fits tight up against the frame for the best approach angle.
-Laser cut and CNC Formed from heavy duty 3/16" thick steel plate.
-Includes two Billet steel tow points welded onto the bumper (D-ring shackles are extra REC-2100).
-No grille obstruction; the winch "tray" is sunken down into bumper (between frame rails) for optimal air flow to the radiator.
NOTES:
-This product is un-painted (except for the winch tray and tow points).
-Aluminum fairlead pictured is not included, but sold separately (FBB-5001).
-Because of the recessed winch tray a Warn 9.5TI winch can be made to fit with minor modifications and the
Warn Power Plant winch can be made to fit with major mods.
![](https://www.jeepz.com/forum/images/imported/2013/09/FBB_8000_WINCHPLATE_800copy_zps3ca61f1d-1.jpg)
___________________________________________
JK Rear Bumper, Steel - BLEM
SKU RBB8200-BLEM
This is a BLEM of the new 2 hole style Steel Rear JK bumper.
Here is your chance to save $100 OFF
And get a flat shipping rate of only $50!
Damage is so minor you may not even be able to tell!
Other Features:
-100% MIG welded (as pictured)!
-Weighs about 50lbs (ligher than most!).
-Laser cut and CNC bent, heavy duty 3/16" steel construction.
-2 Heavy Duty tow points are welded to the bumper.
-Sticks back less than 4" behind the body!
-Includes a small integrated small entry step, just below rear door.
-Improves departure angle over stock bumper.
-Can still be used with factory receiver hitch.
-Completely independent of the rear tire carrier (factory tire on the rear tailgate can be retained).
-Easy to install.
NOTES:
-The D-Ring "hooks" for the rear tow points are sold seperatly (REC-2100).
-The (2) holes in the rear bumper make an excellent spot to mount our new LED back up lights (LED1500).
-Sold Un-painted.
-GenRight Tire Carrier does not attach to the rear bumper and is sold separately.
![](https://www.jeepz.com/forum/images/imported/2013/09/RBB8520_Rearview_xl_2HOLE_zpsa6780bdb-1.jpg)
JK Rocker Guards, 2 Door STEEL - BLEM
SKU RCG8002-BLEM
This is your lucky day!
We have a couple pair of 2 door JK rockers we are considering to be BLEM. Now is your chance to buy the for $100 OFF and a flat shipping rate of $50!
Hurry supply is limited!
FEATURES:
-3 piece design is is contoured to the body.
-Wraps all the way under to the body mounts for durability.
-Full coverage from front to rear (protects the flares too).
-Laser cut and Formed from solid 3/16" steel plate.
-Works with factory plastic flares too.
-Sold in pairs (as a kit).
-Shipped un-painted and requires paint or powder coat after installation.
NOTE:
-Installation requires minor drilling of the factory mounting locations.
-All sales are final - no returns or exchanges!
-Although the formed metal steps provide good foot traction in most conditions, the metal tubing can be slippery
when wet, therefore we recommend adding grip tape where necessary for better entry and exit foot traction.
-Will require trimming about 5/8" off the bottom of the factory flares.
![](https://www.jeepz.com/forum/images/imported/2013/09/RCG8002_onWhtJK_xl_zps6ab4e4fa-1.jpg)
____________________________________________
JK Rocker Guards, 4 Door STEEL - BLEM
SKU RCG8004-BLEM
We have a couple pair of 4 door GenRight Rocker Guards that got blem'd in our warehouse. The damage is slight, if fact you'll probably not even be able to tell.
The deal is $100 OFF and a flat shipping rate of $60!
Hurry the supply is limited!
FEATURES:
-Highest ground clearance on the market (hangs no lower than the body).
-3 piece design ties into multiple points for maximum durability.
-Contoured to fit the shape of the JK's curved body.
-Wraps all the way under and ties to the body mounts.
-Laser Cut and CNC Formed from solid 3/16" steel plate.
-Smooth "Boatside" will not get hung up on trail obstacles!
-Will work with metal tube flares or the factory plastic flares.
-Shape design acts as a nice 4" wide step for the vehicle occupants.
-Includes all Stainless mounting hardware.
-Shipped un-painted and requires paint.
-Made in USA!
NOTES:
-All sales are final - not returns or exchanges!
-Although the formed metal steps provide good foot traction in most conditions, the metal tubing can be slippery when
wet, therefore we recommend adding grip tape where necessary for better foot traction during entry and exit.
-Will not work with body lifts (attaches to the bottom of the body mount bolts).
![](https://www.jeepz.com/forum/images/imported/2013/09/GR_JK_3qtrFV_xl_zps1f710b68-1.jpg)
JK Rear Bumper, Steel (4 Light Style) Powder Coated
SKU RBB8200-4P
This is the Steel JK rear bumper from GenRight Off Road.
It is sleek, simple and made of heavy duty 3/16" thick steel plate.
It has two receiver type clevis mounts built into the bumper for super strong tow points that tie into the frame.
This is the old style of rear bumper that includes the 4 holes to mount LED back up lights (LED1500 or LED1001S). These bumpers are brand new, unused from the factory. These rear bumpers have a semi gloss black powder coat finish applied to them.
This is a special limited time offer while the old style is in stock! Once these are gone they will not be coming back.
Other Features:
--Includes a small integrated small entry step, just below rear door.Improves departure angle over stock bumper.
-Easy to install.
NOTES:
-The (4) holes in the rear bumper make an excellent spot to mount our new LED back up lights (LED1500).
-Sold Un-painted.
-GenRight Tire Carrier does not attach to the rear bumper and is sold separately. Steel (RTC3800) or in Aluminum (RTC3810).
![](https://www.jeepz.com/forum/images/imported/2013/09/RBB820004P_xl_zps85759518-1.jpg)
SKU RBB8200-4
Other Features:
-Easy to install.
NOTES:
-Sold Un-painted.
![](https://www.jeepz.com/forum/images/imported/2013/09/RBB_8200_800copy_zpse465690f-1.jpg)
JK EVAP Skid - BLEM
SKU COSKP8000
This is a BLEM heavy duty Skid Plate for the EVAP canister under the Jeep JK 2 door and 4 door.
Normally $110 on SALE for only $80 and FREE shipping!
The damage is to the corner on the powder coating - function is 100%!
Constructed of 3/16" steel and powder coated black.
Re-uses all the factory EVAP canister hardware.
Sold each.
![](https://www.jeepz.com/forum/images/imported/2013/09/SKP8000_SV_xl_zps7370db57-1.jpg)
SKU FBB8000-3
NOTES:
SKU RBB8200-BLEM
Other Features:
-Easy to install.
NOTES:
-Sold Un-painted.
SKU RCG8002-BLEM
FEATURES:
NOTE:
SKU RCG8004-BLEM
FEATURES:
-Made in USA!
NOTES:
SKU RBB8200-4P
Other Features:
-Easy to install.
NOTES:
-Sold Un-painted.
SKU RBB8200-4
Other Features:
-Easy to install.
NOTES:
-Sold Un-painted.
JK EVAP Skid - BLEM
SKU COSKP8000
Sold each.
