lift help
GREER216
A couple questions on lifts, I have a 2000 tj sport with a 2" body lift on 31" tires I wanna put 33" tires on it and im about to put 2" spring spacers on will that work? Will I need anything else, cam bolts, longer shocks, sye, .......
Yes it will work and yess it will fit the 33" tires, but you may have a bit of rubbing on the swaybar with the steering wheel cut all the way in either direction. It's not a big deal though.
You definitely don't want to add any more body lift (and in fact I would think about lowering the body lift to 1-1.25" and getting a bigger suspension lift in the future). You won't need an SYE. I will note that it is possible you may have some driveline vibrations even with a 2" lift, but many people get away without having to do a t-case drop or SYE on just a 2" lift. Cam bolts are not necessary either. Longer shocks would be a good idea to get the most out of your suspension. I don't think you'll need anything else.
