Loking For a air compresor
shevyluv69
RE: I
loking for air compressor to put on my portable welder it needs to be belt driven and 12volt ingage like an ac compressor. I know alot of Jeeps are runinng york pumps I need somthing that will last longer. I have gone through 4 yorks 1 a year. any help would be great.
RE: Re: Everyday driver and moderate off road
4 Yorks, 1 per year? Either you're using it A LOT or something isn't right. Are you keeping well lubed and running an air filter before the intake? Running it too long and getting it too hot? If you are, mabye try a high heat, full synthetic oil like Redline or Royal Purple but I don't know if that'll make any difference at all. Have you tried the mod to keep the oil inside the compressor to reduce discharge? I don't know much about other a/c compressors so don't know if there's anything better out there but I'm sure there probably is. Mabye a 12 volt electric compressor would be better. If you try contacting www.onboardair.com , they might be able to help you out.
