Need some help, broke the zipper on my rear window......
montana_jeepn
It was sticking and while I was attempting to un stick it, it just popped off. When I tried to pry it apart so I could get it back on, it broke into two pieces. Any suggestions on how I can fix this? Supposed to rain Monday so looking for a known fix. I'm sure I'm not the first. Thanks in advance.
M _J
I had the same problem
I took the zipper that stays on the left side off cause the pass side zipper broke off .
1. first thing take the zipper stop off on the lower right corner of the top
2. slide the zipper all the way down the right side comming off the track .
3. Slide the zipper back on MAKE SURE THE FLAT SIDE POINTS UP !!!!! .
4. put the zipper sop back on where you took it off from.
5. get some one to help you hold the window and install it
(it helps if the side flaps in the rear arent attached to the tub)
Ive been doin this for the past 5 months on my TJ
if its tooo much trouble goto an auto upolstry shop theyll charge ya $200
