need sum info
yj87
hey well i have an 87 yj with a 4 inch bds lift and a 1 inch body lift . I would like to get the **** cepek f-c ll 35 inch tires and was woundering the pros and cons of this... Will they fit ? It will be mosty for daily driving. Occational mudding and that is it. Any help is great thanks
HAHA, the jeepz site censored D I C K ... Those are decent tires too.
Anyway, they would probably fit but with some rubbing. I would try to get an extra inch of clearance in there, probably your best bet is to put some TJ flares on there and cut away the extra steel away from the fenders. I would keep an eye on your backspacing on the rim so the tires don't hit the leaf spring pack too. What size tires do you have on there now?
Oh and welcome to Jeepz!!
Well right now i have 30s But those look stupid with the lift. I was gonna get 33s but i cant resist the 35s for 10 bucks more a piece. So i should get tj fenders which will run me about what ? 100$ or so ? And cut the metal on the front and back wheel-wells ? Is this alot of work ? It wouldnt have to be perfect because it would ber covered up be the flares right ?
i should get tj fenders and by that i mean fender flares
one more question. Whats the big difference between the yj and tj flares, they look just about the same in all the pics that i have seen. Do you think it will still rub with those and if so how bad ?
