currupt4130
VT Hokie
Re: RE: Sorry if i come across as a mean-o
so i found a better alternative to my transmission swap. the np435 is a ford transmission with 6.6, 3.09, 1.7, 1 gear ratios, much better than the sm420 and i can still adapt it to my jeep for the same price, driveshafts might need to be lengthened which is always a plus. does anyone know anything about this transmission that i should kno, anything bad? im actually looking for torque ratings on it versus the sm420 and t-18 if anyone knows where to get that.
the modifications to put this transmission in include
a new input shaft
a new mainshaft
an adapter plate for the bellhousing to transmission, (which is why you need a longer mainshaft, older models had the longer one so its not super outrageous to change it.)
and and adapter to go to the tcase, which is where the mainshaft comes in, ill also need a new input gear for the tcase so if anyone has a 23 spline input gear let me kno, preferablly a 94.
what does anyone think about rotating my 231 perfectly flat? any pros or cons? i can re-drill the adapter to do so and i might be able to make an almost flat skid out of 1/4inch or 5/16 plate!
a new input shaft
a new mainshaft
